Hi all
Q1. anyone got an idea what are those tires ??
Q2. What is the maximum tire height for a stock M715 ?
Q3. What tires you recommend for an original M715 rim ?
Hi all
They look like they were hand cut.
Max size with a stock truck is about 38"
I currently have 36" bias ply Super Swampers. Bias ply keeps them narrow, but it rides rough until they round out.
Those are Michelin XML's (military) and they have been siped.
The rims are reversed also. the inside is now outside. also its on rockwell axles with a spring over. man m715,s are cool..............
I don't think those are Rockwell axles. And I don't think the rims are reversed.
It looks like stock axles with custom built wheels to me.
There isn't a lot of room above the tires so I would guess it only has a spring over suspension lift and some fender trimming on the front fenders.
Check out four wheeler magazine top truck challenge. It will give you the specs on the truck. Those are 49" tires also.
It also says they are 46/16/20 Michelin's. Maybe they are 49"s on those rims? Google " Fourwheeler Top Truck Challenge M715".
Now I had to go look....
Yup...
Axle ratio:
6.72:1
Wheels:
20x10.5 double bead lock
Kinda cool rear winch, and he is running an NP 205 ...
http://www.fourwheeler.com/top-truck...7-kaiser-m715/
hostis est intra portas tuas
Its easy to spot rockwells, it could be that spicergear fellas truck from pa I think
Thank you ALLLLL
Dam this forum is gooood
