I dont want to do anything stupid.
I have a parts truck, with the stock M 715 Dana 70 rear axle, and a spare rear Dana 70 that I want to do a direct swap with.
The parts truck will eventually run again... its not far off actually.
The U bolt measurements for the rear are 8 and 1/2 inches from the top of the U bolt to the end of the threads.
The pitch is 1/2 inch fine thread.
All that is good to go..
the U bolts that I'm looking at are 3 and 5/8 inches wide, between the threads
The stock spring perches require 4 inch spacing.
I "think" CL to CL... but I'm not 100 % on that.
What is your opinion about stretching these to fit 3/8th's of an inch in width?
From reading here , I understand about not re- using the stock U- bolts, due to thread pitch cut and possibility of breaking if You re- use the old U bolts.
So.. they get replaced.
Do you guys think I can get by with stretching these that 3/8 th's of an inch in width ?
Just dont want to do anything stupid. "again" : )
[IMG][/IMG]
