I finally ordered a Detroit 225S14 locker for the rear axle
($399 at Summit after $50 rebate and free shipping).
http://www.summitracing.com/parts/dtl-225s14/overview/
After reading some of the write-ups on the install, the book specs the carrier bearing torque around 110 ft-lbs, but it sounds like the stock bolts are prone to stretching and most set them around 80-90 ft-lbs... I have also gathered that the length is not a size that most generic hardware stores carry. The only size I have seen posted here was a guess: 1/2" by 16TPI 2-3/8.
Does anybody know the actual size of the rear carrier bearing cap bolts?
I would like to order some quality () replacement grade 8 bolts and have them on hand for the install.
Thanks for the help.
