I've had a NOS ignitor, plugs and wires for some time and today I got it, the new plugs and stock wires put in. Last fall we pulled the oil pump to get proper gear alignment as I was off 90 degrees from the previous owner and wanted the ignitor to be correct. Those "e-bay" plug wire wrenches are crap as you can't get it on the second wire in the pair. The newer plugs are longer and there is no wrench clearance due to the angle. Had to make due with grinding the wrench thinner. Truck fired right up!!
Also was glad I had the military timing light adapter as it works great. I bought that adapter set some years ago also but never used it. I was lucky and the timing was right on without making any adjustments. Not usually the way things go here!
