Pan gasket replacement
I was thinking that maybe it's time to drop the oil pan and clean out the sludge that settles at the very bottom. Because the oil drain hole is slightly above the bottom, I'm pretty sure over the years, the bottom of the pan has some sediment in it. Please correct me if I'm wrong.
If I go ahead and do this, where's a good place to get a new oil pan gasket?
Are they rather easy to come across? Anything special involved with removing the oil pan?
Any help would be appreciated, thanks.
