What are the "Air lines / Vent lines" that go to one side and out the other side of the Distributor for? When I bought the truck most were closed off with bolts stuck in them. Where can I find a diagram of the venting system? Thanks, Nate
Nate, if you check the online manuals above, there are clear illustrations and some pictures of where the lines go. Not trying to be quick but I have to go and get ready for work right now (I am in Australia right now). If no one can answer, I will try to take time later today and look it up.
Ron is so correct (as usual). I had a Mallory dual-point distributor and the plastic parts would just vaporize. I suspect it was not venting properly.
Check out this post:
Air Cleaner Assy Ports
