Hello, is there anybody can tel me wich type powersteering box fit in my m715 and were to buy??
Thanks In Advance Best Regards Harry Arnoldus
not sure of type but someone will post the info you need
1969 M715
Basically, any Saginaw power steering box that mounts inside the frame rail and is in front of the axle. Full size Jeep trucks and Wagoneers are the best source. However, CJ's had them too. So did most GM cars from 1968-1990. There are lots of post here about them if you want to search.
The steering boxs show up on ebay from time to time.
Hello Jeeper
i will lift the truck 3'' is this the good pitmanarm what i need ?
Thanks For your info
I'm not really sure if you could use that pitman arm with a lift. Someone else may chime in and answer that.
Someone makes a drop arm for lifts for this steering box. Might be BJ's.
Here 'tis:
http://www.bjsoffroad.com/ProdList.asp?scat=45
Scott
