I did the trans OH ,had both front &rear drive shafts out, I put them back the way they were. the front diff drive shaft has the slip joint end bolted to the transfercase, & the rear diff driveshaft also has the slip joint end bolted to the transfercase is this correct ? cant find this information thanks boonie
