AB Linn has the Np200 gasket kits yet as mentioned.
I made my own axle gaskets.
[IMG][/IMG]
Get a piece of steel pipe or tubing about 6 inches long with the same diameter that you need, and grind an edge on a grinding wheel. See the sharp end of the pipe in the pic.
Lay the pre-cut gasket on what you want the pattern from, and tap it with a ball peen hammer to make light indents in the gasket material.
Pound out the holes with the pipe.
Scott
