Hey guys I have already downloaded a ton of info off this website and would like to say thank you for all of it! I did some trading for my truck and pulled it out of a field in TN a few months back. Already did the wheel cylinder conv, new brake shoes, rebuilt rearend, mounted a fuel cell, made my conversion plug wires and many more ignition parts. The trouble im having now is it still won't start. I think I have multiple problems but am unsure as the 230 is a little strange. The first problem I have is I cant spin the engine over by hand, it spins what seems to be fine with the starter though. Secondly im not so sure about the timing even though I have read through the manuals. With the zero degree mark on the timing mark the number one piston is down (number 1 is the first one from the radiator im presuming). Also with the zero degree mark lined up my intake valve on number one is open....
My thoughts were woodroof key sheared on crank and someone didnt set the physical timing up correctly (someone has been into the timing cover at one time). And maybe the bendix on the starter isnt returning is why I cant turn it over by hand.
Any thoughts and help would be GREATLY appreciated. I really need a second opionion before I start pulling the front end apart.
