Where can I find the transfer case rubber mounts.
VPW lists a "transfer case mounting kit" for $150.00 I haven't called to ask what is in it.
Man, I just used the boat roller stock again. I chucked them in a vice and hack-sawed them to 3/4" and viola, new mounts. I did use some oversize washers to keep them from splitting out on the bottom and/or migrating through the frame holes.
I paid $9.00 per roller at a local boat shop and had enough to make all the frame/body bushings with just two rollers total.
my truck only had 8000 miles on it if there still rolling around you can have them just pay for the ride
There is 8 total correct I found 4 so far are your sleeves and washers still good my bushings look real good still. I should be able to find the rest tonight
I lost most of the sleeves and washers unfortunately and still missing a couple bushings still lookin though. cleanin the garage after i get the rocker panel on today though. pm me ur info
pm sent
ok so i still didnt find all the bushings. But i did find a source for y'all international shock bushings are almost dead on perfect
