Old May 25th, 2004, 08:03 PM
Nuke_HammerinGreenBay Nuke_HammerinGreenBay is offline
Civilian
Nuke_HammerinGreenBay is an Observer
I am contemplating the change from the stock engine and trans the a chev 350/turbo 400 combo. Does anyone have thoughts or suggestions positively or negatively? Is there anything to look out for or specifics I need to be aware of. I also know it is a popular but generic swap, it seems the easiest due to motor mount kits and parts etc. comments please. thanks
Old May 25th, 2004, 08:07 PM
Swampthang's Avatar
Swampthang Swampthang is offline
Private 1st Class
Swampthang is a Soldier
Default chevy 350/turbo 400 recommendations
you will probably have to move t-case back as th400 is rather long.
Old May 25th, 2004, 08:20 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default Fresh water's TWO uses:
Hi Hammer....long time no see!!
After seeing 3 big blocks in M715s that had the mounts moved forward about 2 inches....and still had room for stock type fans and did not have the firewall dented for the valve covers or the distributor, I would go that route were I to use a small or big block chevy....it will help a little on the tranny length too!
What tcase..married or divorced....linkage mount comes to mind....there are ways, just depends what you are gonna use.
As ffr as easy, yeah, it is the easiest and most spported swap out there....well the 350 is...I think most go with the 350 trans too....but the 400 is stouter and a good choice for heavy duty service.
HTML code is On
ih200 : Oil recommendations in 230 PseudoZone PseudoZone - Open Archive 5 November 11th, 2009 02:08 AM
chevy 350 and turbo 400 ken ruhland Modified Tech 6 November 16th, 2008 03:38 PM
Trailer recommendations porkchop Open Discussion 4 August 9th, 2008 04:27 AM
chevy 6.2L with 350 turbo solekaukini Modified Tech 11 April 25th, 2008 08:16 PM
Custom Rims and Size Recommendations joesco715 Open Discussion 12 May 6th, 2007 09:18 AM
