Old October 5th, 2012, 05:20 PM
Kevin M715's Avatar
Kevin M715 Kevin M715 is offline
Kevin M715 is a Soldier
Default New Shocks
Anybody have part #'s for new front/rear shocks/...are they both the same?...thanks Kevin
1968 M-715 Ex-Brush Truck
Old October 5th, 2012, 06:36 PM
militarypotts's Avatar
militarypotts militarypotts is offline
Sergeant
militarypotts is a Soldier
Quote:
Never thought much about shocks on the truck Kevin. Glad you brought up the question, look forward to seeing the answer. Thanks.
Old October 6th, 2012, 05:36 AM
Kevin M715's Avatar
They look easy enough to replace as far as access....mine look original and the bushings have some slight play in them....figure a new set couldn't hurt.
Old October 6th, 2012, 06:32 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
I got new shocks for my truck (actually NOS) from VPW. The original ones on the truck were not bad but the rubber bushings were gone. So, if you disconnect one end and try them, they may be OK. Maybe you can find the rubber bushings. They are two piece and easy to install if I remember correctly. I don't remember if I replaced the back ones. I will check next week when I see the truck again...
Old October 6th, 2012, 07:46 AM
maskale maskale is offline
Sergeant
maskale is a Soldier
If u are just concerned about bushing u can get new rubber or poly ones pretty easy. Auto Zone and places have them or eBay, amazon. Just need to measure them and order the right size. Pretty much just goes off the sleeve size.
Be sure to measure front and back, top and bottom. They are different in lots of cases.
  #6
Old October 6th, 2012, 08:06 AM
Don Cavey's Avatar
Staff Sergeant
And to add to the above, they are two piece with the opening in the shock being somewhat tapered from the outside (double taper) making installation straightforward and easy.
  #7
Old October 7th, 2012, 01:15 PM
Kevin M715's Avatar
Thanks Don, The 45 yr old bushings are shot, If the shock feels good then I'll just replace the bushings....
  #8
Old October 7th, 2012, 02:20 PM
Don Cavey's Avatar
Staff Sergeant
Yes. My shocks were beat up but useable. However, I already had the new ones and just replaced them. Very easy. I would bet you can get the rubber bushings that you need...
  #9
Old October 7th, 2012, 02:53 PM
Sergeant
Shocks are relatively cheap for the cheap ones, which are better then those old ones. Once u get a part number of the correct length. It would seem J truck shocks would swap. Once u got them off I say go for new and be done. Factor in cost of bushings vs new ones, might not be much more.
  #10
Old October 7th, 2012, 05:39 PM
97XJSP's Avatar
97XJSP 97XJSP is offline
Private 1st Class
97XJSP is a Soldier
A lot of times you can buy shocks without any part numbers, just by knowing the extended and collapsed lengths (eye to eye), which are usually published by manufacturers. The bushing style is fairly common, making both the new bushings and new shocks pretty easy to find. I would consider "cheap" shocks to be somewhere in the $30 ea. range...
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
