Old September 4th, 2012, 10:33 AM
jrok93003's Avatar
jrok93003 jrok93003 is offline
jrok93003 is a Soldier
Default Cummins Mount
I am planning a CUMMINS swap into a m715 and I just wanted to know how you that have done it mounted the engine? fordcummins.com makes kits for fords and chevys, would this work? Will the cummins set into the stock mounts on the 715?
Any help needed
Old September 4th, 2012, 01:12 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Mikel has done more of them than I have and probably has better suggestions. The one I did, we started with a frame that already had the stock perches removed, so we built our own. They are pictured in the thread titled 6bt, CUCv axle...
Old September 4th, 2012, 02:32 PM
maskale maskale is offline
Sergeant
maskale is a Soldier
If you have the frame, or can find a frame I would take the crossmember or mounts off the dodge truck and make them fit the M frame. As heavy as a diesel is I would think a crossmember would be good so the engine isnt trying to spread the frame rails.
Old September 4th, 2012, 05:05 PM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
I like using 1st generation mounts. Contrary to popular belief, if you locate the engine properly, a lift is not needed the hood/axle.
This is my friend's:
Old September 4th, 2012, 05:11 PM
Sergeant
Mikel is a Soldier
For the rest of the stuff, I would stick with Dodge parts. Relatively cheap and plentiful.
  #6
Old September 6th, 2012, 04:47 AM
defbob's Avatar
defbob defbob is offline
Private 1st Class
defbob is a Soldier
1968 M715
1968 M725
  #7
Old September 6th, 2012, 07:47 AM
tndonor tndonor is offline
Private 1st Class
tndonor is a Soldier
Since any part or kit you but to mount a Cummins in will still need modification, I would suggest starting from scratch with your own stuff and dial it in to exactly what you want/need.
  #8
Old September 6th, 2012, 12:21 PM
wrecker's Avatar
wrecker wrecker is offline
Sergeant
wrecker is a Soldier
I think Chris Unger has that set up. Maybe shoot him a PM.
  #9
Old October 9th, 2012, 07:13 AM
jrok93003's Avatar
Has anyone used a stock crossmember out of a dodge truck to put a Cummins in? If so I need details and pics if possible. Also how far back did you weld the crossmember in? Any help.
  #10
Old October 9th, 2012, 02:16 PM
Sergeant
Mikel is a Soldier
Quote:
I did look into using a 1st generation crossmember, but it appeared that it would hit the axle. If you have a lot of lift that may not be a problem. But I wouldn't go by my quick measurements...
1998 - 2019
Copyright 1998-2019
