I put in a new radiator about 3 years ago in my truck. Works fine, trucks operates at a constant 190 degrees. Question is this...... Water level in radiator just barely covers cooling fins when you look into radiator. If I add the slightest amount of water to it, after a short drive to get the truck up to temperature, it spits it back out to the old level. Very picky about how much coolant it will accept. Is this normal? Thanks.
