Results 1 to 4 of 4
Thread: 350 / 400 turbo swap
    Default Misc. pointers for swapping in an SBC or BBC cheaply-
    Looks like I might have a oppurtunity to pick up a Chevy 350 with a 400 turbo at a reasonable price. I was hoping anyone with experience with a swap like this to let me in on the do's and don'ts and what all is needed to get it in. I assume I would need to fab new mounts and a new / modified shaft to the transfer case, but what else do I need to plan for?
    A way to mount the t-case shifters and e-brake handle. They are mounted to the bellhousing trans on stock trucks.
    Make sure to put the jackshaft in. I had a turbo 350 in mine with no jackshaft (just a u-joint) and it caused the case to tranny to split.
    It's pretty straight forward. You can use motor mounts from a 1970 truck with the V-8 and they'll bolt to the frame horns, but you'll have to beat a dent in the firewall to fit the passenger side head of your v-8. Then make a mount for the turbo 400. The biggest headache you're gonna have is finding a hose for your water intake that will clear the fan. If you want to use electric fans then it's a breeze. Your stock radiator will be right on the line as far as keeping the 350 cool. Some do, some don't. I know mine would until I ran it on the highway in summer for over 10 minutes at top speed.
    Good luck and let us know if you run into any problems.
    -B.
    Iam no expert here brian but Ive seen 2 427's...Spicer's and Joe/IA's...and a ford what ever(Found on road dead) in 2 different trucks with no smashing...Humm
  1. 6.5 turbo
    By foodstamp in forum Open Discussion
    Last Post: April 4th, 2011, 01:12 AM
  2. chevy 350 and turbo 400
    By ken ruhland in forum Modified Tech
    Last Post: November 16th, 2008, 06:38 PM
  3. chevy 6.2L with 350 turbo
    By solekaukini in forum Modified Tech
    Last Post: April 25th, 2008, 11:16 PM
  4. Turbo 350 question???
    By jzoliver in forum Modified Tech Archives
    Last Post: May 18th, 2004, 12:32 AM
