Old March 30th, 2004, 11:40 PM
Nuke_mcinfantry Nuke_mcinfantry is offline
Nuke_mcinfantry is an Observer
i cannot use the stock lever and both shifters for my truck...
i need both shifters for the twin stick transfer np205
anyone fab a center style pull one?
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
Old March 31st, 2004, 07:04 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Center style in that the e-brake is between the two shifters?
or center style in that the e-brake pivot point or connection to the rod is in the center instead of on the bottom of the handle?
or are you trying to put the t-case shifters and the e-brake handle in the middle of the tunnel above the trans and behind the 5-speed shifter?
Sorry about the questions, but I am lost as to what you need.
Old March 31st, 2004, 07:17 AM
Swampthang's Avatar
Swampthang Swampthang is offline
Private 1st Class
Swampthang is a Soldier
Mc, how about using a civvie bark brake pedal that mounts on left kick panel or a pull-up style lever like between the seats on front-drive cars. you would have to redo the cable but that ain't no thang for you.
Old March 31st, 2004, 08:12 AM
Swampthang's Avatar
Private 1st Class
Lee, were you able to use the pintle hitch?
Old March 31st, 2004, 09:48 AM
yes, thanks for the hitch!
ok, i mean a t handle that pulls from the center of the dash, or under, like on mazda trucks and older cars. pull the t out to lock, then twist to unlock. to twin stick my new transfer i need the levers side by side, not in line. also my disc tansfer brake wont work. the cummins sheared it off! the whole bracket!
1967 M-715 (A1)
  #6
Old March 31st, 2004, 09:55 AM
Barrman's Avatar
Chief 9-flats
Toyota, Mazda, and the old Chevy LUV had them. I don't know about Nissan or some of the other foriegn brands. Almost all airplanes have them also. Some of the airplane ones, Piper for instance, worked with the hydralic system to lock up the brakes. I don't know the particulars since as just a private pilot, I am not allowed to work on planes.
  #7
Old March 31st, 2004, 02:59 PM
Swampthang's Avatar
Private 1st Class
cj2a's had this style. Jc whitney may have a replacement for them as I am sure they go bad with time.
HTML code is On
fisherman : Brake line pressure switch for brake lights. fisherman PseudoZone - Open Archive 12 November 11th, 2009 09:33 PM
