Results 1 to 4 of 4
Thread: Power Brake Lock up!!
    Added power brakes last fall. New lines, wheel cylinders, a J-4000 booster setup. Works great with one exception. If ya ain't careful, you will lock all the tires up with only very little pedal push. Did I miss someting in this setup? Maybe some kind of proportional valve or something? Things work great, but eatin' the windshield is getting old. I mean I can literally lock all four tires at 60 mph and come to an instant halt. But when you are trying to stop say at the end of he street, wham! you stop instantly. Any ideas out there?
    VaM715
    parsons Kansas
    sounds like your mastercyl was designed for larger wheel cyl. and maybe discs. pushing way more fluid than needed to do the job on the 715s. may step down to a j-3000 mastercyl. or your part store guru may be able to match wheel cyl. sizes with master cyl. piston sizes and come up with somethin that will work for you. hope this helps some.
    Dave
    67 M725, 67 M715, 68 M715
    Leave it together and back down the adjustment a little. What pads did you use? Maybe run the booster to a less signal vacuum port. What tires do you have? If your running stock NDT's the don't have a lot of tread contact with the road to begin with.
    Big Blocks RULE!
    The cesspool of WA state
    I believe the J trucks share the same system as the wags. There is a brake proporting valve on the frame under the drivers side firewall. You might try one of those. I think BJ's offroad has them new. It might help.
    Liz, covid, murdered 10/19/21
  1. J20 Power brake booster and MC
    By tngreenmachine in forum Modified Tech
    Last Post: August 27th, 2012, 09:40 PM
  2. fisherman : Posi or Power Lock?
    By fisherman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 02:05 AM
  3. Open diff or Power lock?
    By fisherman in forum Open Discussion
    Last Post: October 20th, 2008, 10:59 PM
  4. rear brake lock up
    Last Post: April 14th, 2008, 07:16 AM
  5. winch lock
    By Roger1952 in forum Stock Tech
    Last Post: April 15th, 2007, 01:24 PM
