Old April 10th, 2010, 09:52 PM
bacardi's Avatar
bacardi bacardi is offline
New Recruit
bacardi is a Soldier
Default Hummer H1 rims with adapters
So i got a sweet deal on some Hummer H1 rims/tires(11.00 h 16 XL) and decided to have a machinist make some adapter plates to mount on the stock axles. I should of asked here 1st but it was a spur of the moment kind of thing.
My question is: will i have any trouble with the extra weight of the wheels on the stock axles?
question 2: i plan on taking "Hector" out on some trails but nothing tooo extreme and wondered if there are any weak points that will come up with the heavier rim/tire combo?
edit: whoops pics are massive lol, I'm just gonna link them
http://imgur.com/bsWdj.jpg
http://imgur.com/lTBtH.jpg
Old April 11th, 2010, 06:13 AM
Cornholio's Avatar
Cornholio Cornholio is offline
Private 1st Class
Cornholio is a Soldier
Hi Bacardi,
I'm pretty sure those are not H1 rims but rather LAV rims. Probably a set of takeoff tires/rims when they switched to the 20" size.
I was thinking about going the same route but haven't found a source of those rims yet.
Some of the M37 guys have made adapters to bolt those wheels to their trucks. Check out this link http://www.texaspowerwagon.com/LAV-1.htm
I talked to a guy on Steel Solders who was thinking about making a set for the M715 but apparently there was not enough interest to make it happen. I think it is doable but you'll have to have a machinist buddy help you out.
Good luck!
Old April 11th, 2010, 06:34 AM
glenn glenn is offline
Corporal
glenn is a Soldier
Talk to Snake River 4x4, they make adaptor plates for bolting gamma goat rims on the 715.
Old April 11th, 2010, 02:06 PM
bacardi's Avatar
New Recruit
wow thanks guys! You learn something new everyday! i guess the seller didn't know what he had!
The machinist will be done with the rim adapters on Monday(once the wheel studs i ordered come in) and ill post pics of the results!
Old April 12th, 2010, 10:32 AM
militarytrux's Avatar
militarytrux militarytrux is offline
militarytrux is a Soldier
I'm interested in seeing the adapters you're using? did you make the 6 x 7.25 into a standard 8-lug pattern? I thought the 8 lug pattern was smaller and I did'nt think that would work??
  #6
Old April 14th, 2010, 08:33 PM
phoenix's Avatar
phoenix phoenix is offline
Private 1st Class
phoenix is a Soldier
Quote:
If they were Hummer rims, it would not work. They are off of one of the bigger trucks.
  #7
Old May 21st, 2010, 02:25 PM
friedm715 friedm715 is offline
Basic Trainee
friedm715 is a Soldier
Quote:
Do you mean these particular adapters won't work or that an adapter that would be custom made for the H1 wheel onto the M715 hub won't work?
  #8
Old May 21st, 2010, 03:09 PM
rollie715's Avatar
rollie715 rollie715 is offline
rollie715 is a Soldier
Quote:
Adapters for the H1 8-bolt style won't work as the H1 bolt circle diameter is too small.
The larger adapters shown should work fine.
Dana60 14bolt H1 hummer rims Tomahawk715 Modified Tech 8 November 29th, 2009 06:01 AM
Tow bar adapters Kaiserjeeps Stock Tech 4 May 13th, 2008 07:44 PM
Wheel adapters gimpyrobb Open Discussion 0 February 18th, 2008 08:13 PM
More on hummer wheels M715AKACHARLIE Modified Tech 18 December 3rd, 2007 07:10 AM
HUMMER TIRES Swampthang Open Discussion Archives 14 April 9th, 2004 01:12 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
