Old February 21st, 2010, 05:53 PM
Duane's Avatar
Duane Duane is offline
Corporal
Duane is a Soldier
Default spare tire mount rear attaching pic
ok, can someone post a pic on how the rear part of the tire carrier attaches to the frame? is there a bolt? or a catch? I do not have a hole in my frame where a bolt would attach? any help would be appreciated
Duane
Old February 21st, 2010, 07:13 PM
kyken's Avatar
kyken kyken is offline
Sergeant
kyken is a Soldier
On my bumper,below and right of where some idiot used a torch to rid of the pintle hook is a bolt hanging. That is where the tire carrier rests. The other end is the bracket just above and to the left of the pumpkin. Hope this helps...Ken
Thanks for all the help!
Old February 21st, 2010, 08:34 PM
fng's Avatar
fng fng is offline
Sergeant
fng is a Soldier
Hey Ken, is that you in the pic?
Old February 22nd, 2010, 01:14 AM
kyken's Avatar
Sergeant
kyken is a Soldier
No, but we do have the same barber ; p
This was the 1st time I drove the truck back in November '09. I went around the block to a shop for a complete lubrication. The only changes since then noticable in the pic is a new exhaust system and tires. How do I fix that darn bumper/pintle? Guess I need an artist with a cutting torch and a welder.
Old February 22nd, 2010, 08:12 AM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
Find a scrap frame with a good rear crossmember and replace yours with donor trucks.
  #6
Old February 22nd, 2010, 12:01 PM
Duane's Avatar
Corporal
Duane is a Soldier
So the carrier runs on an angle to the right side the pintle, I was thinking it ran straight back, I am assuming you need to tighten and loosen the nut to remove the hanger.
I will look for the hole in the frame when I get home.
Duane
  #7
Old February 22nd, 2010, 02:01 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Actually its a bolt that goes in the frame...kind of long...think I have an imagine somewhere...maybe later I can post that...
Yes, it runs at the angle.
  #8
Old February 23rd, 2010, 06:57 AM
Duane's Avatar
Corporal
Duane is a Soldier
luckily, the hole is there and the threads are intact, anyone have the lenth of the bolt? if not I will figure it out when I put the tire up
Thanks for the pic and info
Duane
  #9
Old February 23rd, 2010, 07:15 AM
brute4c's Avatar
Grand Poobah
I think I posted those once...lets see...
Well...I dont see the specs off hand anymore...but I do have the pic of the bolt:
Maybe someone else can measure for you...
I found a thread that has pics of an installed carrier...not the best but it might help...and this is with an oversize tire and the stock carrier is modified a little but it does how the basic idea.
http://m715zone.com/vb/showthread.php?t=6758
  #10
Old February 23rd, 2010, 07:34 AM
brute4c's Avatar
Grand Poobah
Heres an even better pic of a stock mout in place:
Spare Tire Mount for 38-Swamper dummy Modified Tech 1 March 11th, 2008 07:25 AM
Spare Tire in Bed dhood Modified Tech 15 August 3rd, 2007 11:28 AM
Moving/Re attaching rear arched Cross member alosix Modified Tech 10 May 7th, 2007 06:04 PM
M-725 spare tire rpgdeity Stock Tech 16 February 28th, 2007 02:26 PM
spare tire hanger rjenkins Modified Tech 1 January 7th, 2007 06:23 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
