Old December 15th, 2009, 05:20 PM
Moderator
PseudoZone is a Soldier
Default tomahawk715 : Painless wiring
Painless wiring
Post by tomahawk715 on Nov 20, 2006, 9:35pm
Anybody here use a Painless wiring harness to convert to 12 volt? If so which kit did you use (kit part number??)? I'm looking at a Painless GM universal truck harness-mainly to get the length so I have no splices to the rear light harness>>>>On a similar note--I've heard there is a convert bulb chart available somewhere (24v-12volt) but my cousin cant remember where he saw it. Gives the 12 volt equivelents for the 24 volt bulbs-fit in the same carriers. Tried a google search but I'm getting alot of wierd matches to my seaches.
Old December 15th, 2009, 05:21 PM
saxon saxon is offline
Corporal
saxon is a Soldier
Default saxon :
Re: Painless wiring
Post by saxon on Nov 20, 2006, 9:53pm
I bought a painless 12 circuit harness P/N #10107 bronco,land cruiser,scout,new in box 2nd party. I took it out of box to check just that, (verify length) seemed plenty long for our trucks, I got mine cheap but hav'nt installed it yet. Dan
Moderator
Re: Painless wiring
Post by tomahawk715 on Nov 20, 2006, 10:14pm
Thats the concern-dont want to replace 40 year old wiring to improve reliability just to end up with a bunch of splices-water always seems to find em.
Elohim1 Elohim1 is offline
Elohim1 is a Soldier
Default elohim1 :
Re: Painless wiring
Post by elohim1 on Nov 20, 2006, 10:54pm
I ordered the universal waterproof Harness 10140 . Painless said there is 25ft. wire for the rear , 16ft. wire for the front. $459 from Summit racing. I hope to receive and start installing this week.
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Re: Painless wiring
Post by compexp on Nov 20, 2006, 11:03pm
I used the universal truck kit with dash ignition - http://store.summitracing.com/egnsearch.....DS=1&N=700+1 15
Plenty of wire - just a tad snug on the passenger tail lights - but that was because I centered my fuse block behind the gauges - unfortunately, that's where the heater ducting goes.
Well labelled and I have plenty of circuits left to use.
If I was doing it again - I would mount the fuse panel in a waterproof box under the hood.
  #6
Corporal
saxon is a Soldier
Default saxon :
Re: Painless wiring
Post by saxon on Nov 20, 2006, 11:07pm
I will look at that as a possible, Thanks
  #7
Moderator
Default tacomainoh :
Re: Painless wiring
Post by tacomainoh on Nov 21, 2006, 12:54am
That Summit kit is just as good. I checked it out in person. Save some bucks and get quality at the same time.
  #8
Moderator
Re: Painless wiring
Post by tomahawk715 on Nov 21, 2006, 8:22pm
Compexp-Just checkin-that kit you got from summit is a Painless kit then?? I see it says standard length-Going by what you said about mounting it under the hood it if you did it over----would it have then been too short?? I see they do have a kit listed as universal truck long....
I see a ton of the cj kits and bronco ones on ebay but the truck ones seem rare as hens teeth
  #9
Moderator
Default neptco19 :
Re: Painless wiring
Post by neptco19 on Nov 21, 2006, 8:58pm
Check with these guys here at Ez wire http://www.ezwiring.com/ Not sure how long the rear harness wires are but they might have a option to get them longer than standard.
  #10
Moderator
Re: Painless wiring
Post by tomahawk715 on Nov 21, 2006, 10:28pm
Found the conversion chart for bulbs 24v to 12v
http://www.steelsoldiers.com/index.php?m....fid=file&pid=45
HTML code is On
Need wiring help ldj1002 Open Discussion 3 September 17th, 2009 08:36 PM
Turn signal switch/painless harness Craig Merrill Modified Tech 6 March 9th, 2009 08:41 AM
painless wiring harness? spgirard30 Modified Tech 9 February 8th, 2009 02:31 PM
Aftermarket Wiring Harness - Painless Type Fastfrankie Open Discussion 6 November 19th, 2008 01:50 PM
Wiring archjr Open Discussion 2 January 28th, 2008 03:42 PM
