Results 1 to 6 of 6
Thread: robscj : axle swap
    Default robscj : axle swap
    axle swap
    Post by robscj on Sept 16, 2006, 8:30pm
    sorry to bring this up once more but Just got a set of axles dana 60/14 bolt 4.56 gears
    well the ? is how much of a prob is it to do the swap is it prety much bolt on or some /alot of mods
    Default robertcowan :
    Re: axle swap
    Post by robertcowan on Sept 17, 2006, 3:19pm
    alot of mods not for the novis builder
    Default robscj :
    Re: axle swap
    Post by robscj on Sept 17, 2006, 11:11pm
    was trying to get genral idea ? well I guess there are going on the cj
    Re: axle swap
    Post by robertcowan on Sept 18, 2006, 1:47am
    if your good enough to put them under a cj then you can put them under a m715.
    Atlanta, Ga.
    Default bluesman2a :
    Re: axle swap
    Post by bluesman2a on Sept 18, 2006, 11:31am
    Agreed. With a CJ you have to outboard the front springs, HUGE PITA.
    With a stock truck you will need the following:
    1) rear axle -- Have to run disc brakes, drums won't fit. See www.bluetorchfab.com for the right brackets (lots of people make them, but these work best from my perspective.
    2) rear axle -- need to move spring perches out and weld on, can leave old ones in place.
    3) Driveshafts -- need a 1310 to 1330 conversion u-joint for at least the rear, think the front is OK.
    4) The clearance on the DS to the gas tank is CLOSE. I chose to lose the stock tank rather than chance it.
    5) Front axle -- If you go SUA (stock) you will need to build a spring perch for it, both top and bottom so the u-bolt can clamp.
    5A) If you go SOA, you will need to relocate the stock perches outboard. Driver's side is easy. Passenger side is PITA. You will need to extend the cast perch and whack the web off the underside of the pig so you can get the u-bolts around the bottom.
    5B) If you go SOA in the front you will need to flip the shackles in the rear and/or use blocks or some other method to level out the truck.
    5C) If you go SOA, plan on getting new/lengthened driveshafts.
    If you know enough to work on your own CJ, 715's are pretty straight forward.
    Default robscj :
    Re: axle swap
    Post by robscj on Sept 19, 2006, 9:53pm
    Thank you !!!! That was the info i was looking for
  1. dana 60 front axle and diff swap
    Last Post: April 7th, 2010, 09:13 AM
  2. Axle swap questions
    Last Post: November 13th, 2009, 10:52 PM
  3. m725 axle swap
    By wantapinz2 in forum Modified Tech
    Last Post: October 7th, 2009, 01:36 PM
  4. 14 Bolt FF Rear Axle Swap
    By BigBlockBurris in forum Modified Tech
    Last Post: January 13th, 2008, 09:54 AM
  5. CUCV Axle Swap
    By kalikraven in forum Modified Tech Archives
    Last Post: February 7th, 2004, 11:25 PM
