Go Back   M715 Zone > General Tech > Stock Tech > PseudoZone - Stock Tech Archive
Old December 15th, 2009, 12:20 PM
Moderator
PseudoZone is a Soldier
Default fastfrankie : Stock points/condensor/dwell/etc.
Post by fastfrankie on Dec 3, 2006, 3:18pm
Where can I get some new points and condensor for my stock 24 volt 230? AB Linn? I am sure Memphis has them but they are pricey...I wonder if these could be had at a local NAPA? Part numbers?
What gap do people use? The .020 stock setting?
How do I hook up my dwell meter? I have an old style dwell meter with needle and a newer digital one? What one is better to use? Any help on how to hook it up etc would be great.
My truck was always hard to start, especially cold, regardless of what the temperature was outside - summer or winter. I go to check the points and the screw was loose on the holdown and the point were at about .010. I regapped the points to .020 and now it runs/starts fairly quick. The old points do look a bit worn though...
Thanks, Frank
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
Default kwai :
Re: Stock points/condensor/dwell/etc.
Post by kwai on Dec 3, 2006, 5:12pm
AB Linn usually has them.
Moderator
Default mthomsen :
Post by mthomsen on Dec 3, 2006, 7:13pm
The napa part numbers-
Points- Echlin #Cl725A
Condensor- Echlin #A131a
If you have a carquest near, here are the numbers for them.
Points- AL4556xp
Condensor- AL118x
Rotor- AL154 (note, this rotor takes some very minor modification to miss the condensor)
Basically make it look like the one that you take out.
I use the .020 setting for the points.
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Post by brute4c on Dec 4, 2006, 11:04am
That is the right points gap....to hook up a dwell meter one needs to know what the particular meter wants...mine is a Sears unit and it hooks up with one lead clipped to coil negative and the other to a good ground. I prefer the dwell method myself.
Which unit would be better? As long as they are both accurate, its probably a moot point.
The dwell setting for a stock military ignition:
38? to 44?
An ignitor dwell angle of more than 44? (small gap) may cause hard starting. A reading of less than 38? (large gap) may cause engine to misfire at high speeds or underload.
Moderator
Post by fastfrankie on Dec 4, 2006, 1:22pm
Brute....
How do I hook up the dwell lead to the coil wires since the coil is encased under the cap housing? Do you remove the large bolt/cover on top of the distributor cap housing to attach the lead to the coil negative?
Also, those NAPA numbers for the points and condensor are no good at my local NAPA...the guy plugged them in and had no luck. I Guess I will have to call AB when I get home...the only thing that's a bummer about him is that he doesn't take credit cards....that mean I have to go and get a money order and mail it to him which delays everything an additonal week....
  #6
Old December 15th, 2009, 12:21 PM
brute4c's Avatar
Grand Poobah
Default brute4c :
Post by brute4c on Dec 4, 2006, 1:43pm
The big hex on the ignitor housing cover over the coil is the place to go through to hook up to coil negative. That is the test port for diagnostics anyway...so that is the place.
  #7
hiker's Avatar
hiker hiker is offline
Corporal
hiker is a Soldier
Default hiker :
Post by hiker on Dec 4, 2006, 3:33pm
Try these NAPA parts, They work, but a bit pricey. show available Echlin brand:
Contact set (points) CS 725A $13.49
http://www.napaonline.com/MasterPage...PartNum=cs725a
Condensor AL869 $7.49
http://www.napaonline.com/MasterPage...&PartNum=AL869
Rotor AL166 $10.49
http://www.napaonline.com/MasterPage...&PartNum=AL166
  #8
Moderator
Default mthomsen :
Post by mthomsen on Dec 4, 2006, 6:02pm
The numbers i listed were old numbers, hikers numbers are the cross for the old ones. Parts guy just was to lazy to get the book out, and cross them.
  #9
Moderator
Post by fastfrankie on Dec 4, 2006, 7:34pm
Well I ordered a set of points from AB Linn...$11 shipped to my front door.
I went to start my truck today cold and she just cranked and cranked. The points were a bit worn and rough so I guess I will replace them when I get the new points and go from there. I have had this problem for a while now. I will recheck the timing now that I gapped the points the other day to see where I am at. I am at wits end with this hard starting problem!!
HTML code is On
binfordm715 : How do I hook up my dwell meter? Binford PseudoZone - Stock Tech Archive 3 December 15th, 2009 11:58 AM
ignition condensor 5quarter Stock Tech 25 January 26th, 2009 08:52 PM
Points and Condenser for Stock Distributor rboltz Stock Tech 1 December 22nd, 2007 05:01 PM
Dwell meter adk4x4 Open Discussion 6 April 30th, 2007 02:00 PM
Points & Dwell law Stock Tech Archives 1 March 1st, 2004 07:04 AM
