Go Back   M715 Zone > General Tech > Stock Tech > PseudoZone - Stock Tech Archive
Old December 15th, 2009, 12:07 PM
Moderator
PseudoZone is a Soldier
Default agengr : Changing a Fuel Pump
Post by agengr on Oct 22, 2006, 5:00pm
This Friday, I plan to swap the stock mechanical fuel pump on my truck with one from a spare engine. I've looked through the manuals and found some diagrams but no instructions on the removal of it and how to put it back on. I am not so sure how the pump is driven by the engine, so my question is: Is this a fairly simple bolt off/bolt back on procedure or are there tricks and little things to watch out for?
Moderator
Default robertcowan :
Re: Changing a Fuel Pump
Post by robertcowan on Oct 22, 2006, 5:44pm
UNHOOK ALL THE LINES AND IF YOU CANT REBEMBER WHERE THEY GO MARK THEY OR TAKE PICTURES, TAKE THE 2 NUTS OFF HOLDING ON THE FUEL PUMP , IT MIGHT BE STUCK SLIGHTLY FROM GASKET SEALER, GENTLY TAP IT WITH RUBBER HAMMER OR SIMMILAR ITEM, REOMVE PUMP STRAIGHT OUT, CLEAN GASKET SURFACE GOOD, INSTALL NEW GASKET WITH SEALER ( THIN COAT ON BOTH SIDES ) INSTALL PUMP STRAIGHT IN , IT MIGHT GO A LITTLE HARD THE LAST 1/2" IF THE FUEL PUMP CENTRIC IS IN THE PUMPING MODE. JUST PUSH IT ALL THE WAY STRAIGHT IN, HOLD IT IN AND INSTALL THE WASHERS, & NUTS. TIGHTEN IT DOWN ( NOT LIKE A GORILLA ) HOOK BACK UP THE LINES ( USE WD40 ON THE CONNECTORE IF NOT REAL FREE ). CHANGE FUEL FILTER. CRANK ENGINE.
BOB
Moderator
Default agengr :
Post by agengr on Oct 22, 2006, 8:33pm
Does anyone have a part# for the gasket at Napa, Autozone, etc.
hiker's Avatar
hiker hiker is offline
Corporal
hiker is a Soldier
Default hiker :
Post by hiker on Oct 22, 2006, 9:51pm
Napa part number: NGAD27094
http://www.napaonline.com/masterpages/NO....Mounting+Gasket
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Default barrman :
Post by barrman on Oct 23, 2006, 8:17am
Joseph, 3M weather stripping is great for this kind of use. This is the yellow or black stuff in the red and white tubes.
Glue the gasket to the pump first. Then put another bead on the engine side of the gasket. The stuff is really sticky, so be carefull or wear latex gloves.
HTML code is On
agengr : fuel issues PseudoZone PseudoZone - Stock Tech Archive 12 December 15th, 2009 12:00 PM
need fuel civy fuel pump #s jpsnblood Stock Tech 6 June 24th, 2009 06:00 PM
Fuel pump Q? and hopefully some A's 5quarter Stock Tech 2 May 11th, 2008 05:36 PM
fuel pump doesn't pump. sf38a1 Stock Tech 10 April 11th, 2008 05:58 PM
230 fuel pump krek Stock Tech 12 May 5th, 2007 06:29 AM
