Results 1 to 5 of 5
Thread: airborne : Tire pressure,
Hybrid View
    Huntingtown,Md.
    Default airborne : Tire pressure,
    Tire pressure,
    Post by airborne on Sept 30, 2006, 4:49pm
    What pressure is everyone running in their 1100X16?
    Default kwai :
    Re: Tire pressure,
    Post by kwai on Sept 30, 2006, 9:23pm
    I run around 30-35 psi. Without a load a higher pressure is a rough ride and the XL don't flatten out to get even wear. Others may run higher pressures.
    Default porkchop :
    Re: Tire pressure,
    Post by porkchop on Oct 1, 2006, 9:05am
    I am running mine at 50 psi. On my truck it tracks better down the road with the higher pressure.
    Huntingtown,Md.
    Default airborne :
    Re: Tire pressure,
    Post by airborne on Oct 1, 2006, 11:38am
    Thanks. Just looking for a ball park to start with.
    Default barrman :
    Re: Tire pressure,
    Post by barrman on Oct 2, 2006, 12:39pm
    Anything below 70 on my XZL's and my front tires started to scuff real bad on the outside because of the rear locker. I just put them at the 80 psi max.
    If you have open diff's, start them off low and keep adding a little until you get a good even wear pattern. 80 psi is a ruff ride.
  1. airborne : Shocks,
    By airborne in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 05:46 AM
  2. airborne : Dana 60
    Last Post: November 12th, 2009, 03:12 AM
  3. tire pressure for 38 Swamper TSL?
    Last Post: April 15th, 2009, 08:03 AM
  4. Tire pressure for aftermarket tires
    By randyscycle in forum Open Discussion
    Last Post: March 21st, 2008, 10:54 AM
  5. Best tire pressure.
    By white433 in forum Modified Tech
    Last Post: June 1st, 2007, 11:29 PM
