Go Back   M715 Zone > General Tech > Stock Tech > PseudoZone - Stock Tech Archive
Old December 15th, 2009, 12:00 PM
Moderator
PseudoZone is a Soldier
Default koobster : head bolts
head bolts
Post by koobster on Sept 30, 2006, 4:23pm
What is the touque on the head bolts. I need this info now. getting ready to put it back on.
hiker's Avatar
hiker hiker is offline
Corporal
hiker is a Soldier
Default hiker :
Re: head bolts
Post by hiker on Sept 30, 2006, 7:59pm
(7) Install the cylinder head bolts in all but the guide pin locations with proper washers and tighten them down snugly in the sequence indicated in figure 3-51.
Remove the two guide pins and install two zinc plated cylinder head bolts and washers in their place. In the sequence given, torque all head bolts 80 to 95 lbs-ft, using thin wall socket 34244-2.
(118 of 357) TM 9-2320-244-34 Manual
HTML code is On
koobster : timing chain copper links? PseudoZone PseudoZone - Stock Tech Archive 6 December 15th, 2009 12:09 PM
koobster : head gasket replacement please HELP PseudoZone PseudoZone - Stock Tech Archive 9 December 15th, 2009 12:08 PM
koobster : a few quiks of the a-1 PseudoZone PseudoZone - Open Archive 1 November 12th, 2009 01:06 AM
koobster : 2 barrel carb PseudoZone PseudoZone - Open Archive 3 November 11th, 2009 11:08 PM
