Old December 1st, 2009, 07:43 AM
FlatlinesUp's Avatar
FlatlinesUp FlatlinesUp is offline
FlatlinesUp is a Soldier
Default 10k garwood winch from rear PTO 205?
Is it possible (keeping in mind I'm hard headded and have lots of tools) to mount a 10k Garwood in front and run it from an attached np205 that has a rear facing PTO?
I'm not familiar w/any PTO winch setups and would appreciate any pics/diagrams (or links to them) to help me figure out what I'd need to make this happen.
Thanks gents!
Britt
FL^
Old December 1st, 2009, 08:17 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
There was a former member that had 10K garwoods at both ends of his M715. A different pto to run each though.
All you need is a shaft that turns to power the winch. A rear facing pto could be made to work with triple row chain and sprockets to get the power going to the front.
Old December 1st, 2009, 08:18 AM
snakeater's Avatar
snakeater snakeater is offline
snakeater is a Soldier
most pto outputs can be swapped from front to back facing. Running a front mounted winch from a rear facing pto isn't impossible, just lots more engineering than you should have to do. I will call you in a little bit. Snakeater
COWBELL, you need more of it
jeepcj : Rear mount pto winch PseudoZone PseudoZone - Open Archive 7 November 11th, 2009 09:50 PM
rear winch M715AKACHARLIE Modified Tech 12 March 11th, 2009 11:27 AM
Garwood winch 646dan Modified Tech 3 February 27th, 2008 08:33 PM
Rear Winch Install w/ Pics Jay Dog Modified Tech 3 August 4th, 2007 09:48 AM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
