Results 1 to 10 of 10
Thread: maddawg308 : Dropping tank, cleaning process?
    Default maddawg308 : Dropping tank, cleaning process?
    Post by maddawg308 on Jul 13, 2006, 10:00am
    Will be dropping the gas tank this weekend. External condition is light surface rust in some places, but solid. I am expecting the internal condition to be pretty good, since it has always had a cap on it. Gas tank is empty.
    What's the best way you have all found to clean the tank and seal it to prevent future internal corrosion? Any products you would recommend?
    Default brute4c :
    Re: Dropping tank, cleaning process?
    Post by brute4c on Jul 13, 2006, 10:53am
    Find a radiator shop that can run your tank through the process called:
    RENU
    That is THE best thing going.
    Mar 2004
    northern Arizona
    Default compexp :
    Post by compexp on Jul 13, 2006, 1:02pm
    had a rad shop do mine.
    Default k8icu :
    Post by k8icu on Jul 13, 2006, 8:18pm
    Is the RENU the stuff that puts a ceramic coating on the inside of the tank?
    Washington State
    Default fisherman :
    Post by fisherman on Jul 13, 2006, 8:22pm
    I ordered the por 15 tank restoration kit before I dropped mine. I looked inside no rust anywhere just clean galvanized looking metal, and a very clean shiny pickup tube with screen. I will not be doing the Por 15, just adding a 12 volt sending unit for the 12 volt conversion coming up. Your tank might be just as clean. Fisherman
    Default brute4c :
    Post by brute4c on Jul 14, 2006, 9:07am
    My tank was just like that fisherman...and I did what you did too...thogh I had the outside sanblasted for the rust spots, not bad really, and then painted with an enamel base and had it rhino lined on the outside.
    Washington State
    Default fisherman :
    Post by fisherman on Jul 14, 2006, 11:48am
    I de rusted mine, and then painted it, I think I will use some nice undercoating on it. It was just too clean to warrant putting in any kind of sealer.
    Auburn, AL
    Default snuffy :
    Post by snuffy on Jul 15, 2006, 10:06am
    Can someone explain RENU a little... I'm not familiar with it. Is this insude the tank or or external?
    Thanks,
    Snuffy
    Default bigwheelbob :
    Post by bigwheelbob on Jul 15, 2006, 11:26am
    http://www.gastankrenu.com/how.htm
    Default k8icu :
    Post by k8icu on Jul 15, 2006, 5:12pm
    Still don't tell me what it is. Ceramic? Rubber? poly raszamataz? I'd like to know.
  1. maddawg308 : Fuel tank sending unit
    Last Post: November 12th, 2009, 06:43 AM
  2. Fuel Tank Cleaning Again
    Last Post: November 7th, 2009, 11:19 AM
  3. Dropping Windshield with Fording Kit
    By Cornholio in forum Stock Tech
    Last Post: August 28th, 2009, 07:28 PM
  4. Cleaning rusty gas tank
    By Calpyro in forum Open Discussion
    Last Post: March 15th, 2007, 03:58 PM
  5. Making some process w/ pics
    By jeepfan93 in forum Open Discussion
    Last Post: February 3rd, 2007, 10:34 PM
