Results 1 to 9 of 9
Thread: fsjguy : Heat from space between cab and bed
    Northern Colorado
    Default fsjguy : Heat from space between cab and bed
    Post by fsjguy on Jun 16, 2006, 11:06pm
    I have an AMC 360/TH400/QT combination in my 715. I am feeling a lot of heat radiating up from the space between the cab and bed. (open bikini top for the summer)
    Has anyone else run into this problem? I am thinking that a heat shield made of sheet metal would help things. Any other suggestions?
    TIA
    Default tacomainoh :
    Re: Heat from space between cab and bed
    Post by tacomainoh on Jun 16, 2006, 11:24pm
    where are your mufflers?
    but yeah, a heat sheild would probably help. Most modern vehicles are shielded around at least the mufflers....
    Northern Colorado
    Default fsjguy :
    Post by fsjguy on Jun 17, 2006, 9:25am
    Muffler is under the bed, between the front (forward) of the bed and the rear axle.
    Maybe it's time to recharge the AC that Alan installed.
    Default socal715 :
    Post by socal715 on Jun 17, 2006, 2:27pm
    Mine gets extremely hot in that area too. I have the stock setup (Tornado 230OHC and NP200).
    I swear i could roast marshmellows back there
    Northern Colorado
    Default fsjguy :
    Post by fsjguy on Jun 17, 2006, 9:59pm
    Thanks, Socal. Good to know someone else has the problem, too. I'll try a heat shield and see what happens.
    Default poolmike :
    Post by poolmike on Jun 18, 2006, 6:47am
    I took a length of pipe insulation for 1.5" pipe and stuffed it in between the bed and the cab. Problem solved. That heat was unbearable at times.
    Default firefightinsam :
    Post by firefightinsam on Jun 18, 2006, 8:17pm
    I haven't noticed too much heat but the weather here in So-Cal has been 100+, what I have noticed is an incredible amount of noise from what may be the same source the np200.
    Default brute4c :
    Post by brute4c on Jun 20, 2006, 9:12am
    I know on mine that when the tcase overheats, there is furnace type heat rising in the gap between cab and bed till it cools...also a 12 pack of pop practically boils if left behind the passenger seat...if you look from the passenger sde at the tcase location versus the cab, its right at the rear of the cab...and no other problematic heat sources are there stock...
    Aftermarket exhaust, as mentioned above, depending on the routing and mufflr location, can also be your culprit.
    Default barrman :
    Post by barrman on Jun 20, 2006, 10:02am
    Mine had the heat problem with the stock set up. I stuffed the pipe insulation in the gap and it worked for a while and then fell down or popped up depending on my speed. I ended up welding some 1" angle iron to the front of the bed and then using 1" rubber molding stuck to the cab and the angle iron. Been good for almost a year like that. I will get a picture if you want.
  1. fsjguy : Tire Balancing with Dynabeads
    By FSJGuy in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 02:02 AM
  2. fsjguy : Wheel Balancing
    Last Post: November 10th, 2009, 11:53 PM
  3. Front fender trim for tire space?
    By Seven in forum Modified Tech
    Last Post: May 18th, 2007, 09:10 AM
