Results 1 to 10 of 11
Thread: vam715 : Pintle hook and hitch question?
    Default vam715 : Pintle hook and hitch question?
    Post by vam715 on Jun 7, 2006, 3:55pm
    After owning this truck for 7 years, I hate to ask stupid questions, but.........
    Is the Pintle hook supposed to swivel or not? Mine sits a little crooked, won't move, and I've never had it off and I noticed a NOS on Ebay that showed it as a shank with a nut.
    And does anybody have a part number for a bolt on style Reese hitch? I notice a couple of you have a "Hidden Hitch", but I'm not a good welder and need something with ease of installation.
    Thanks,
    VaM715
    Default brute4c :
    Re: Pintle hook and hitch question?
    Post by brute4c on Jun 7, 2006, 4:12pm
    The pintle hook is supposed to swivel and should have a total of 3 grease fittings....one on the left side of the lever you lift to open it....one on the left side side of the jaws opening point...and finally one on the right side, more rearward, to get grease in around the mounting shaft so as to keep it rotating...
    Here are the 2 on the left:
    The one on the right, where the grease gets direted onto the mounting shaft, the one you really need, can be found in this illustration as #10:
    Port Orchard, Wash.
    Default binfordm715 :
    Post by binfordm715 on Jun 7, 2006, 4:22pm
    Good to know, Jon. Mine is upright, but doesn't turn at all. Jaw opens and such. Never really looked at it before. I'll have to check for the grease fittings and see if it will free up. I just figured the Forest Service had welded it or something!
    Default robertcowan :
    Post by robertcowan on Jun 7, 2006, 4:48pm
    PUT A LOND PIPE OR BAR INTO THE CLOSED jaws and close the jaws the rotate the pintle hook. this will free it up. bob
    Post by robertcowan on Jun 7, 2006, 4:50pm
    also i,am in the beginning of building a heavy duty reciever hitch setup for the m715 that is equal to the quality of the truck . not the class 3 type that everybody uses but a heavy duty version, one the truck could hang from type h-d. i,ll have kits for sale when i get it all engineered out. i want them to be as good as everything else i build and sell.
    bob
    Default jeepistdougiowa :
    Post by jeepistdougiowa on Jun 7, 2006, 4:56pm
    Adding some heat from a propane torch will only help what Bob suggested. Loosens up old grease so you can push some new in.
    Default twodogs :
    Post by twodogs on Jun 7, 2006, 5:55pm
    Mine has a zerk on the bottom of the rear X member. Is that a production change?. Field modification? ('68 model).
    I too have been on a hitch hunt. Found this:
    http://www.etrailerpart.com/Receiver.../universal.htm
    Think it'll work?
    Default warwick :
    Post by warwick on Jun 7, 2006, 8:07pm
    my 68 M715 has the same
    two on the left
    none on the right
    one on the bottom of x-member
    Default brute4c :
    Post by brute4c on Jun 7, 2006, 8:32pm
    Mine has one there too....actually I was at work when I typed the above and thought it was on the frame but I went by the manual...couldnt run out and look....maybe I'll get a pic later...
    Default rjenkins :
    Post by rjenkins on Jun 7, 2006, 8:47pm
    I plan on pulling the pintle out cutting the area to fit a universal reciever blank. (19.99) With that done I will shorten the threaded portion of the pintal and weld a square tube section (from a draw bar) over it. When it is installed it will look stock and be removable to be replaced with a drop hitch.
  1. Starter switch hook-up
    By buzzbike71 in forum Stock Tech
    Last Post: April 22nd, 2010, 01:57 PM
  2. warthog : Pintle hook
    Last Post: November 12th, 2009, 01:22 AM
  3. airborne : heater hook-up
    By airborne in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 12:48 AM
  4. Pintle..
    By SouthernM715 in forum Stock Tech
    Last Post: February 1st, 2008, 08:52 PM
  5. Use for pintle hitch
    By webstercj8 in forum Open Discussion
    Last Post: April 11th, 2007, 01:26 PM
