Results 1 to 6 of 6
Thread: wrecker : dual tanks
    Jan 2007
    Fort Smith, Arkansas
    Default wrecker : dual tanks
    dual tanks
    Post by wrecker on May 18, 2006, 8:55am
    I'll be installing a rear tank from a full size van where the spare tire was originally mounted, and keeping the original tank also. I plan to connect the two with the valve and switch setup from an 84 chevy truck that had dual tanks. The subject came up right before the server wnet down and I'd like to know if anyone remembers the issue with the rear tank being higher than the front causing problems. There was a lot of talk about fuel draining to lower tank but I think all this was without the switchover valve. Does anyone know if the valve will positively prevent fuel draining? Or am I gonna need some sort of check valve also?
    Port Orchard, Wash.
    Default binfordm715 :
    Re: dual tanks
    Post by binfordm715 on May 20, 2006, 8:42pm
    I think it would be perfect if the aux tank was higher than the stock tank. Then you need only connect the two with a fuel flow line out of the lower portion of the aux tank and a breather connecting the two near the top. As you pulled fuel out of the stock tank, it would also pull out of the aux tank and the fuel level indicator would be accurate-plus! Then when the aux tank ran out, you'd only be pulling from the stock tank and the level indicator would let you know when it was close to empty. Fill-up would fill both tanks from the stock filler neck.
    Why not, eh? KISS and everything.....
    Default jeepistdougiowa :
    Re: dual tanks
    Post by jeepistdougiowa on May 21, 2006, 12:06pm
    The problems were due to the lack of a switchover valve...you should be fine.
    Jan 2007
    Default wrecker :
    Re: dual tanks
    Post by wrecker on May 22, 2006, 8:47am
    Tim, I already have all the stuff for free, so I was planning on using the switchover setup to know when I was empty in each tank and mainly because I have to have my stock tank relined, resealed, and a new sender installed. With the swithover valve, I can isolate each tank and repair the other if needed. I do appreciate the feedback though.
    Port Orchard, Wash.
    Re: dual tanks
    Post by binfordm715 on May 22, 2006, 10:26am
    I was just thinking out loud is all! I had the same switchover setup in my '83 Chevy p/u and really liked it.
    Default brute4c :
    Re: dual tanks
    Post by brute4c on May 22, 2006, 10:46am
    That ability to cut one tank off in case of a problem or maintenance makes that switch worth it right there...to me anyway...that is a good point.
  1. bluesman2a : Let's talk tanks...
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:34 AM
  2. Gas tanks
    By Ronner in forum Modified Tech
    Last Post: October 15th, 2009, 10:13 AM
  3. Dual fuel tanks
    Last Post: May 14th, 2008, 11:11 AM
  4. NOS gas tanks...
    Last Post: November 11th, 2007, 07:04 PM
  5. gas tanks swap
    By kaiserkoski in forum Open Discussion
    Last Post: March 25th, 2007, 11:27 AM
