Results 1 to 6 of 6
Thread: dj : Engine lifting eye
    Default dj : Engine lifting eye
    Engine lifting eye
    Post by dj on May 7, 2006, 9:04pm
    I finally sorted through all the pieces of my pile of M715 parts,and cannot find anything that looks like a lifting eye for the front of the motor. I did find the rear one. Ive looked in the manuals and only the rear one has a picture. How do you guys lift the motors in these,doesnt seem like there is much place to put a chain.I could probably fabricate a lift eye if I had a picture and knew where it bolted on.
    Thanks for any help. DJ
    Default brute4c :
    Re: Engine lifting eye
    Post by brute4c on May 7, 2006, 9:48pm
    Front is the same as the rear...I'll have to check where it bolts...
    Default dj :
    Post by dj on May 9, 2006, 10:10pm
    Thanks , Brute,I've looked at the motor for too long ,and cant figure out where the bracket would go.Can any one with a stock (Tornado) motor help me out?
    Thanks DJ
    Default oilcan :
    Post by oilcan on May 9, 2006, 10:19pm
    I didn't have one on the front of mine, so I wrapped a strap around the motor. Easy as pie.
    Default barrman :
    Post by barrman on May 11, 2006, 7:40am
    Here is where mine is.
    Default dj :
    Post by dj on May 11, 2006, 9:55pm
    Thanks , to all, "a picture is worth a thousand words".
    DJ
  1. Lifting eye's on engine
    By fng in forum Stock Tech
    Last Post: January 25th, 2009, 12:04 AM
  2. progress on lifting my 715
    By militarycckw in forum Modified Tech
    Last Post: April 13th, 2008, 08:20 PM
  3. questions about lifting my 715?
    Last Post: March 2nd, 2008, 09:45 AM
  4. Lifting Shackles too narrow
    By Cornholio in forum Stock Tech
    Last Post: November 21st, 2007, 07:55 AM
  5. Rock lifting harness
    By MarknessMonster in forum Open Discussion
    Last Post: May 12th, 2007, 05:57 PM
