Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: dougbrsp : Oil leak help to find oil seal
    Default dougbrsp : Oil leak help to find oil seal
    Post by dougbrsp on Apr 24, 2006, 2:50pm
    Hi, I'm from Brazil and in the M715 zone official forum I'm already asked by this, my M715 has a oil leak from the left back wheel but is hard to find here en Brazil the correct seal for fix it.
    The oil drips between the item 38 and 39 in fig 14-2 (1 and 5 in fig 2-90), wetting the brake parts too, I need to find in the drawing the correct oil seal that allow this happen and a online shop where can I buy using VISA so I can buy and ship to Brazil.
    Default brute4c :
    Re: Oil leak help to find oil seal
    Post by brute4c on Apr 24, 2006, 4:53pm
    The seal you need is #27 in the first pic and #2 in the 2nd pic. I dont know of any of the surplus places that export but you can try:
    Vintage Power Wagons
    Website: http://www.m715kaiserjeep.com/
    Hours of Operation: 8:30am-5:00pm Central Time Mon-Fri
    Toll-tree Order Line 1-888-695-0578
    For questions and price quotes please call (641) 472-4665
    Memphis Equipment
    Website: www.memphisequipment.com
    Address: 766 South Third St.
    Memphis, Tn 38106
    Phone: 901-774-0600
    Fax: 901-946-1919
    Surplus City Jeep Parts
    Website: http://www.surplusjeep.com/
    Address: 4514 Pacific Heights Road
    Oroville, CA 95965
    E-mail: surpluscity@surplusjeep.com
    Phone:1-800-3-JEEP PARTS (1-800-353-3772) or 1-530-533-2500
    Any of them should have the seal you need...heres the info to get the correct one:
    Name: SEAL, REAR WHEEL, INNER
    Federal Stock Number: 5330-864-5774
    Reference Number: 11640818
    If you have trouble getting one this way, let me know...
    Lone Pine, CA
    Default luckypabst :
    Post by luckypabst on Apr 24, 2006, 6:40pm
    See if this makes sense:
    Nunca conf�na borracha velha!
    It's much safer to trust the life of your brakes to new rubber rather than NOS rubber.
    Can you order from Napa? Here's a link to the very seal you need.
    http://napaonline.com/MasterPages/NOLMas....+-+H%2fD+T ruck
    Chris
    Default brute4c :
    Post by brute4c on Apr 24, 2006, 8:45pm
    Will they ship to him I wonder? It would be a better to use new than NOS....for certain!
    Lone Pine, CA
    Post by luckypabst on Apr 24, 2006, 9:04pm
    Dunno. Hopefully.
    Looks like the link dosen't work anyhow, even copied and pasted. The Napa website gives you a place to search either the Napa #27601 or a non-Napa #, either way it comes up with the same seal at about 20 bucks.
    Chris
    Default robertcowan :
    Post by robertcowan on Apr 24, 2006, 9:17pm
    BETTER MAKE SURE its a wheel seal and not a wheel brake cylinder leaking. the only way to see is to remove the brake drum. i bet its a brake cylinder. check your fluid level in the master cylinder to see if its low.
    bob
    Default brute4c :
    Post by brute4c on Apr 24, 2006, 11:05pm
    I have replaced both rear axle seals due to leaks and never had a wheel cylinder leak...well the fire incident but thats different...
    Could be either...
    Default dougbrsp :
    Post by dougbrsp on Apr 25, 2006, 5:37am
    Thanks all
    Brute4c, I'll try to make contact to these dealers, thanks, the important is that now I know the correct item numbers and description, thanks.
    luckypabst, thanks, yes it's make sense , I'm tried to see on the NAPA but they only ships to the US .
    robertcowan, I have sure that's not an oil break leak, because the oil that drips from the wheel have the SAE 90 caracteristic smell and texture, otherwise when I remove the wheels to fix the leak I'll see the state of the wheel cylinders.
    The Kaiser M715 is directly equal to with model of the Gladiator Jeep? I'm asking this, because close to here (in Argentina) have a lot of this Gladiators trucks so I can try to find this there.
    There's no modern truck that uses this same axle (dana 70)? Like the F350 or other? If have I can try to find the seal on local dealers too.
    Thanks again.
    Default brute4c :
    Post by brute4c on Apr 25, 2006, 9:21am
    None of the civilian Gladiator Jeep trucks used this axle.
    I dont know of a modern axle that uses the same seal...though there may be one or several...
    I would see if anyone can cross that seal number for you:
    NAPA number: 27601
    National Seal Number: 476282
    Timken Zero Duplication Seal Number: 416282
    By the way Lucky, your link works if you copy/paste it and remove the space in the word truck at the end...
    Port Orchard, Wash.
    Default binfordm715 :
    Post by binfordm715 on Apr 25, 2006, 9:30am
    Dougbrsp: What model years are these Gladiator trucks down there? Are they relatively new, or all 30-40 years old like up here?
    Are you able to make payments with PayPal? If so, perhaps one of us (with a PayPal account that allows us to receive funds) could buy the part for you and mail it. Just a thought.
  1. Oil Leak.
    By Beltfed Only in forum Stock Tech
    Last Post: February 26th, 2009, 12:01 AM
  2. Oil leak
    By Beltfed Only in forum Open Discussion
    Last Post: January 16th, 2009, 02:15 PM
  3. Oil Leak.
    Last Post: December 1st, 2008, 12:54 PM
  4. What is this leak?
    Last Post: November 6th, 2008, 01:07 AM
