Old October 16th, 2009, 05:06 PM
Duane's Avatar
Duane Duane is offline
Corporal
Duane is a Soldier
Default Troop seat wood length?
what is the length of the wood for the troop seats? I am measuring about 90 inches, and did a search on board and came up with anything from 87 to 91 1/4
Duane
Old October 16th, 2009, 07:13 PM
Ronner's Avatar
Ronner Ronner is offline
Corporal
Ronner is a Soldier
This is an email I got from Gary a while back in regards to the troop seats:
"The planks are 3" tall by 3/4" thick and the total length is 87"
The screws that attach the planks to the brackets are countersunk by a 11/16th" hole.
The center off the mounting screws are roughly 1 1/2" from the ends of the planks.
The top two planks have screws/bolts (measuring from inside of the bed behind the drivers side) at 1 1/2" - 41 1/2" - 45 1/2" - 85 1/2"
The third rail on down has centered screws/bolts at 1 1/2 - 43 1/2" - and 85 1/2"
The tabs that hold the seat up are 2 3/4" in from the ends.
Now all my measurements were done alone with a 25' tape measure but they are close. I noticed minor irregilarities by 1/16th to 1/8th inches which I think is all about measuring dried up old wood."
Hope it helps.
Old November 15th, 2017, 05:48 AM
Ol Sarge's Avatar
Ol Sarge Ol Sarge is offline
Civilian
Ol Sarge is a Soldier
these measurements were SPOT ON. Made my day when all these planks came together. they look Awesome. thank you
Old November 15th, 2017, 08:39 AM
e8wing's Avatar
e8wing e8wing is offline
e8wing is a Soldier
How meney boards do you need for the complete rack and troop seats?
1969 M715
Old November 15th, 2017, 01:06 PM
44willysmb's Avatar
44willysmb 44willysmb is offline
44willysmb is a Soldier
I just completed mine in the last month using Ronner's measurments. You will need 6 planks for each side. I picked up a set of deuce and a half seats and repurposed the oak for my seats by cutting them down.
  #6
Old November 15th, 2017, 02:18 PM
e8wing's Avatar
e8wing is a Soldier
thanks for the reply 44willysmb
1969 M715
  #7
Old November 20th, 2017, 12:00 PM
chillydog chillydog is offline
Basic Trainee
chillydog is a Soldier
Default M 715 troop seat wood
Thanks for the dimensions. As white oak is getting expensive and hard to find, someone told me poplar is a good substitute, just not quite as strong as oak.
Anyone ever use poplar for troop seats?
Chilly
PS Near me is a hardwood shop, they use red oak, BUT, they told me it would not be good for troop seats, because it is quite porous ( compared to white oak), and has a tendency for the ends of the boards to swell and split.
  #8
Old December 25th, 2017, 05:12 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Let me also say that the measurements were spot on. I used them exactly and drilled the holes with a brad point drill after using a forstner bit to sink the hole for the head of he carriage bolt using a drill press.
Thanks for the research!
Wood Troop seats ronzello Open Discussion 5 February 20th, 2010 06:24 AM
rip68 : Length Of Oak Slats For Troop Seats? PseudoZone PseudoZone - Open Archive 4 November 11th, 2009 01:05 AM
binfordm715 : Troop seat wood specs Binford PseudoZone - Open Archive 31 November 10th, 2009 10:16 PM
Troop Seat Wood Need Specs. BCOWANWHEELS Stock Tech 6 June 2nd, 2007 07:42 PM
1998 - 2021
Copyright 1998-2021
