Today was steering box rebuild day. I installed the power steering on my M715 back last winter as I built it, and should have done the box then, but it was relatively dry albeit a bit covered in road grunge, so I washed it off and used it as is until a week ago when it sprouted a leak at both the input and pitman arm shafts.
A little history on the box: It was procured from e-bay for $30 on a buy it now and $25 to ship it Fed Ex back in November last year. It was from a 1980 Grand Wagoneer. It is the 76 casting. It is a Saginaw 800 series box. It bolted on with zero mods, but does have the metric fittings. I used the pitman arm that was on it and it bolted on with no reaming or modifying. My steering geometry is as stock and does not steer too quickly or erratically. I still need to sleeve the frame for the fourth bolt, but after a couple thousand miles and some wheeling, I have had no issues and it was as tight as when I installed it, when I removed it this morning. Here are some pics of the rebuild. Keep in mind a few things:
Clean is the key word here. There are some very critical valves and seals that rely on almost perfect fit to seal and will only go together if there is NO dirt or debris.
Check all the bearings both thrust and needle roller. They are generally OK as they are immersed in fluid constantly, but if they do wear, they tend to also wear a strange pattern into the rack and sector gears and usually make the box unserviceable.
Flush the pump before reinstalling the box. I did this by blocking the return hose pouring new ATF in the pump while running and hanging the pressure hose in an empty container until it ran clean.
Watch how the box comes apart and goes back together. The recirculating ball type boxes are a bit tricky to reassemble, but not impossible. The rebuild kit comes with instructions and they are a bit generic, but can get you through the job.
Use only clean ATF for reassembly lube.
When you reinstall the box and first start the truck DO NOT stick your hands in the wheel! If there were an issue with the valve, or something was incorrectly installed the wheel could snap sharply to one side removing your arm, hands, digits, etc. Not a good ending to the day.
Here is a good example of the leak points on the Saginaw boxes:
Here is an example of the clean thing I mentioned. These things are full of abrasive filth and goo. This is also a good argument for flushing the power steering on a regular basis:
Here is the 76 casting on the box on the bottom near the front. You can also see the reinforcement web cast over to the pitman arm seal housing:
This is how clean things need to be:
More in the next post .
