Results 1 to 3 of 3
Thread: rear wheel bearings
    Jan 2007
    Winona, MN.
    Default rear wheel bearings
    How are the rear wheel bearings lubed? Out of the diff oil or are they greased?
    they are lubed via gear oil. However, when the axle shafts are removed and replaced, some people will grease the bearings, so they don't run dry before the gear oil gets there.
    John
    Jan 2007
    Winona, MN.
    Thank you.-TB
  1. 230 rod bearings
    By SR. in forum Modified Tech
    Last Post: March 12th, 2010, 03:32 AM
  2. uscgmatt : Rear axle wheel bearings.
    Last Post: November 11th, 2009, 12:02 AM
  3. mikec3820 : need to know wheel bearings
    Last Post: November 10th, 2009, 11:26 PM
  4. NAPA part numbers for front and rear wheel bearings?
    Last Post: January 5th, 2008, 11:33 AM
  5. Rear wheel inner seal...cross reference #
    Last Post: October 22nd, 2007, 11:55 PM
