Results 1 to 9 of 9
Thread: I think I have a 12v, help confirm
    Default I think I have a 12v, help confirm
    I have been reading posts on here like mad. Now after looking aunder my hood a little more, I think I might have a 12v system (kind of). I have a starter with only one wire going to it. The coil says 12v on it. My distributor has clips not screws, and is a Prestolite 4044. With all this said, I have 2 batteries.
    So my questions are:
    Do I have a 12v system
    Still have the plug question- what should I use- as I have civi distributor wires?
    I am including a few pics. I think it might need to be cleaned and tightened up in some way. Any points in a right direction would be appreciated.
    Could only add 2 photos here are other ones.
    The starters look the same no matter which you have.
    A 12 volt coil works great on 24 volts if you have a 3 Ohm resister in the primary wiring.
    What kind of alternator do you have?
    How are the batteries hooked together? - to - and + to + is parallel and means 12 volts. - to chassis ground, + from that battery to the - of the other and then the last + to truck wiring is series and means 24 volts.
    It is +-+, no-neg. So it is a 12v?
    Sorry , so excited, ran out to look at batteries, didn’t look at alternator. It says 14v.
    on the starter, I think the 24V starter has a thick band around it where the band is absent on the 12V starter. You have the 12V starter.
    The alternator, of course, is the dead giveaway. You have a 12V system.
    Pistolnut has had my 12 volt starter for about 12 years now. I forgot about the band.
    A 12 volt Prestolite is something I don’t think I have seen before. Cool.
    Jun 2014
    Eastern Maine
    I have 2 USGI 24v starters, neither have a band, I also see a ballast resistor tucked in by the heater hoses, coil says none required.
    I would like to see a pic of the distributor...if possible...
