Results 1 to 10 of 12
Thread: Steering column
    Feb 2007
    Catskill New York
    Default Steering column
    The collar after the steering wheel on my truck is real loose, actually I think the directional switch is the only thing holding it up. I haven't yet taken it apart yet, but after checking out the manuals section it looks like the upper bearing (20) fits inside the shaft and then the seal (19) does the seal hold the collar in place or is there another part that's not listed? Or am I missing something altogether. Any guidence would be appreciated.
    Mine moves fairly easy...it will pretty much hold its place unless its wheeled then it slides down to the TS switch.
    I dont know a cure off hand...other that a strategically placed bundle tie of the right color...
    It appears that they were designed to sort of friction fit on the base of the wheel on that lip back there......I just got done repairing my cracked wheel, and I added a little bit of epoxy to give the lip a bit more thickness, then sanded it down lightly. The collar now fits snugly on the wheel and rotates with it.
    Feb 2007
    Catskill New York
    never thouht of the friction method, thanks again.
    That collar is orignally pressed onto the bottom of the strg. wheel as the wheels age they crack and distort then the collar falls off. Randycycles repair is the best fix.
    68 M-715 MVPA #2710
    I did the same as randyscycle. It should snap into the grove at the bottom of the wheel but a bit of epoxy will make it stay there.
    Mine kept sliding down too. I pulled tried the 3M weather strip method and it worked for a while. Then I pulled the wheel off and slightly bent the thing in a vise and gently tapped it onto the wheel. Much better.
    Of course, two years later I swapped out steering wheels. The replacement wheel had the rubber seal on the bottom and was stuck to the wheel so well that I didn't even try to get it apart. I just painted both parts together and bolted them on.
    Feb 2007
    Catskill New York
    They're all great ideas. Has anyone tried using the steering wheel repair kit Eastwood Co. offers to fix the cracks in the wheel? Thanks again for the ideas.
    Quote Originally Posted by archjr View Post
    I didn't use the Eastwood kit, but I did use JB weld after bead blasting my wheel and cleaning it thoroughly Once the cracks were filled, I sanded it back down and painted it, and it looks pretty darn good now.
    Geneva, FL
    Blog Entries
    1
    Guys, this collar has a typical seal on the bottom that holds it up snug against the wheel. Even if the top seal is bad it will still stay up snug if the bootom one is ok. When I restored my truck I purchased a new bottom seal. Think I got it from memphis Equipment after cross referencing the stock number. The seal lokk like a larger version of the seal you see in the winch, tranny, xfercase, etc.
  1. Steering column lower bearing
    By moose3d in forum Stock Tech
    Last Post: March 22nd, 2010, 03:12 PM
  2. Steering Column Rebuild
    By Warthog in forum Stock Tech
    Last Post: January 23rd, 2009, 05:27 PM
  3. Steering Column Parts
    By Barrman in forum Stock Tech
    Last Post: June 13th, 2008, 10:43 PM
  4. Steering column question
    By Roger1952 in forum Stock Tech
    Last Post: April 7th, 2008, 05:49 PM
  5. Steering Column Information
    By Grantshire in forum Open Discussion
    Last Post: January 3rd, 2008, 08:20 AM
