Results 1 to 4 of 4
Thread: Tire bracket Bolt 11641025
    Default Tire bracket Bolt 11641025
    A friend found someone in Virginia who makes reproduction tire brackets. Came in primed and ready to go. The only thing it doesn’t come with is the bolt which appears to be specially flanged. My copy of TM 9-2320-244-34P manual just gives a part number but not the specs of the bolt. To avoid stripping the retaining nut, can someone here tell me what the bolt size and thread details are. I’ll guess if I need to but hoping this is info readily available. I don’t exactly have a full set of all bolts to test the nut like I could do with my die set if I had the bolt.
    Thank You.
    I posted the specs years and years ago...dont see them anymore unfortunately.
    This is a pic of the stock bolt for reference though:
    Jan 2011
    Fernandina Beach, FL
    Looks simply like a bolt with a lug nut slipped over it!
    Comments please???
    Thank You
    It’s a start.
    At least I know generally how long and wide.
    When I figure it out I’ll, post the specs here for the next guy.
