Going down to get my hoses fabbed tomorrow. I'm using a FSJ box (not a saginaw 76, thanks Bob) and a GM Pump. Here's a shot of the box:
Of the two holes, one is high pressure and the other is a return but which one is which? In the picture the upper hole is larger than the lower one so if you could use simple terms for me...."big hole is..., small hole is...". Also what kind of fittings do I ask for tomorrow? Is there a name or size I should tell the guy I want? I've already got the box mounted or I'd take him the whole thing.
Also today I took some advice from the threads and cut out the two diagonal braces under the rad and lowered it about 4 inches. Lines up much better with the fan and shouldn't cause any clearance issues with the hood, I was a little concerened about that.
Also here's a picture of the seat bottom I fabbed to mount this after market seat. I had two different types of seat bases so I had to get creative twice! It looks like a mousetrap but it allows about 5 inches of fore and aft travel.
I'll try to get some semi completed shots posted later this week.
