Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Best aftermarket rocker panels?
    New Jersey by Philadelphia
    Default Best aftermarket rocker panels?
    Fellas,
    I need to replace one of my rocker panels - the full length passenger side. Who sells the most accurate reproduction rocker? I'd rather spend a few bucks more for a better quality one if possible. I'd like it to match the stock one on the drivers side - I am pretty anal when it comes to doing my bodywork.
    FYI...I purchased a floor panel from Jeep Panels Plus out of Maine and was not impressed with it at all...I wound up reselling it and made a patch panel myself. I wasn't real impressed with the quality and am hesitant to buy a rocker from them.
    I want to hear from members who recently bought a rocker and INSTALLED it - not hearsay etc. Pictures would be great too if you have any from your install.
    There are several threads on the site of people doing this...some real good pics too of the whole process...
    I think the best part is from Jeep Panels Plus...you can email them at:
    jeepanelsplus@live.com
    Or contact info:
    96 Reservoir Road
    South Paris, ME
    04281
    (207) 743-7671
    Last edited by brute4c; October 30th, 2009 at 10:57 PM. Reason: Updated email addy
    Default Rustys
    I think I got mine from Rustys Jeep. It's been a few years. Its fit well and was about the same gauge as the one it replaced
    Anyone else...??
    Mar 2004
    northern Arizona
    http://cooltruckparts.com/010.aspx
    My body guy just installed mine - said they worked fine, but not quite as heavy as the original sheet metal, but fit well.
    67 M725 67 M715 68 M715
    I bought a pair off of e-bay for a Cherokee FSJ. They fit fine with a bit of trimming, but all I needed was the outer skin anyway.
    The main reason a lot of cheaper patch panels don't fit particularly well is because they are not really designed to be a replacement, but rather to go over top of the rusted panel. Generally they are a bit larger and won't line up once you cut out the damaged part of what you're replacing.
    I just installed a drivers' floor pan in a 1980 Ford F350 truck, and it was made to go over the existing floor as a patch. With a lot of careful trimming and fitting it worked as a repair panel, but not as clean as a true floor pan replacement panel.
    Any part numbers or what years fit from a FSJ??
    I bought a new dealer rocker for a 1969 waggie a couple years back. It was 160.00 and might be able to be cut down. Finding another could be interesting.
    There is a guy on IFSJA that does very nice repro panels for waggie floors which means they will fit the M715 also. He went by GEMOBX or GEMBX or something like that. They looked high quality. He might have moved on to rockers by now. You could PM him and ask.
    Liz, covid, murdered 10/19/21
    Huntingtown,Md.
    Got mine from JCW, a couple of years ago they may still have some.
    1963-1991 FSJ's all use the same rocker panel.
  1. compexp : rocker panels
    By compexp in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 02:11 AM
  2. Body Panels
    By gargemel_622 in forum Open Discussion
    Last Post: January 22nd, 2009, 07:36 PM
  3. Rocker panels/Floors
    Last Post: March 10th, 2008, 08:32 AM
  4. Need Info about rocker panels
    By viperman in forum Open Discussion
    Last Post: February 26th, 2008, 03:13 PM
  5. Jeep Panels Plus....where'd they go?
    By Chumley in forum Open Discussion
    Last Post: December 21st, 2007, 12:39 PM
