No civvy drums work. I dont know of a source for NOS drums...if there is one, they will be expensive...
Like gonz said, from another truck is the source...someone who is already swapping axles.
On the indexing, the hub (the thing with the studs to mount the tire), and the drum need to be checked for runout as a unit in all 3 of the screw positions...the drum to hub mounting screws. The position with the least runout is your boy...mark the combo so if/when you remove a drum, it goes back on as it came off...
If you have the drums turned, take he hub with you and have the shop chuck the drum and hub up in the lathe and turn thm as a unit...you will get a good drum from that.
