Results 1 to 5 of 5
Thread: FSJ heater wiring diagram
    Jester Guest
    Question FSJ heater wiring diagram
    Does anyone have a FSJ wiring diagram that they could post showing the heater wiring?
    Do you have to run the power thru the resistor or could you just run 12V to the heater motor for only one speed?
    txs
    12 volt straight to the motor and you will have one speed, high.
    The resistor drops off some of the voltage and the motor runs slower on those speeds...like 9V, 6V and 3V gets through and the rest is resisted...that would make a 4 speed switch.
    See this thread:
    Heater switches
    Jester Guest
    Quote Originally Posted by amphi View Post
    See this thread:
    Heater switches
    You rock Amphi! That is exactly what I needed.
    Glad it helped there Jester. This comes up every now and then.
    I think Fisherman used a three-position toggle switch for two speeds and Tomahawk used a four-position switch from a FSJ for three speeds. The other thread shows info on how to wire both.
  1. Brake light wiring diagram
    By whiteapeman in forum Stock Tech
    Last Post: January 4th, 2010, 12:08 PM
  2. barrman : Wiring Diagram
    By Barrman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 12:15 AM
  3. M715 Wiring Diagram ?
    By Nuke_Danarchy in forum Open Discussion Archives
    Last Post: February 27th, 2004, 07:44 PM
