Results 1 to 4 of 4
Thread: Garwood winch
    Sep 2007
    Covington, Louisiana
    Default Garwood winch
    I have just installed an M35 bumper with the Garwood 10,000 lb. winch on my M715. After going through some old threads looking for some guidance, I was unable to get a clear picture of the best way to power this winch. I have a small block chevy w/700R transmission (np205 transfer case). Basically, I am unsure if running multiple shafts, chain drives, bearings, brackets etc. is the right way to go or not. I sure would appreciate anyone's input, especially those that have done the same or close to the same setup that I am running.
    By the way, the bumper/winch setup looks great, and will look like it belongs there as soon as I finish modifying the bumper ends. They stick out past the wheelwells by a few inches, and this weekend I plan to notch and bend the ends in for a more finished, stock look.
    I will post pictures next week of what I have done so far. (but the way, the Garwood input comes out almost directly across from the steering box)
    I would love to see pictures of the mounts and bumper. Since I have a M715 with no winch and a complete M35 winch set up minus the winch right now. Another member here, Pistolnut, has a winch M715 with a bad stock bumper and a complete good M35 bumper.
    As far as power goes, some have used a shaft that ends below the winch with a chain connecting it to the winch input shaft.
    Others have had the shaft go under the winch, reversed the pinion inside the winch and used a chain on the front to drive it.
    Another option is to install a hyrdaulic pump on the 205 pto and run the winch that way. Lots of surplus hyrdaulic winch drive parts out there.
    By the way, you need a NP205 specific pto no matter which way you go.
    If you have power steering with the SBC you could run a hydraulic from the PS pump and a hydro motor on the winch.
    I have been thinking of a winch in the rear of my M35 and running it from Hydro pump.
    Feb 2007
    middle Tennessee
    I'd like to see pics also as I have 3 Garwood winches and only one M35a2c and a M715 without a winch. Sounds like you've got some drive issues though. If you can find a hyd. motor and pump it's hard to beat a hyd. winch for ease of mounting and "smoothness" of operation.
    67-m715
    71-m35a2
  1. 10k garwood winch from rear PTO 205?
    By FlatlinesUp in forum Modified Tech
    Last Post: December 1st, 2009, 11:18 AM
