  #1
Old November 15th, 2019, 12:25 PM
Ambulance Driver's Avatar
Ambulance Driver Ambulance Driver is offline
New Recruit
Ambulance Driver is a Soldier
Default Original Tornado Ignition issues
I am in need of suggestions from those experienced with the Tornado 230. Readying the motor for its initial startup after sitting for a few years. I have set the timing static. Cleaned and gapped the new plugs, there is a new rotor/cap/points/condenser and verified there is spark (although the spark seems weak to me). 28volts to the distributor. I have tested the coil and it appears to have passed. The initial spin with starter fluid produced no pop or engine run. I am at a loss of what to testing/procedure to do next. Any pertinent assistance would be appreciated.
__________________
Leave no soldier behind
  #2
Old November 15th, 2019, 04:01 PM
Beast's Avatar
Beast Beast is offline
Sergeant
Beast is a Soldier
Quote:
Double check to make sure you are not 180 off on the dist.
__________________
Dave
  #3
Old November 15th, 2019, 06:00 PM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
What color is the coil in the ignitor? Is it a sorta light gold color or shiny chrome?
  #4
Old November 16th, 2019, 09:04 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Does the distributor rotor actually turn while cranking the engine? My truck quit out of the blue driving through town last month due to distributor drive failure.
  #5
Old November 17th, 2019, 04:03 PM
New Recruit
I have one that is a brass goldish color and one that is shiny chrome
__________________
  #6
Old November 17th, 2019, 04:04 PM
New Recruit
distributor lines up with #1 piston at TDC
__________________
  #7
Old November 17th, 2019, 04:05 PM
New Recruit
yes. the rotor shaft turns with the motor.
__________________
  #8
Old November 18th, 2019, 07:09 AM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
put in a new coil. I have had coils test ok, but still not work.
Tags
230 ignition, 230 no spark, ignition issues, tornado
1998 - 2019
Copyright 1998-2019
