Napa website no longer returns any part numbers for the spring bushings up front...
It was per the zone:
Front Bushing: NAPA 274-6523
Rear Bushing: NAPA 274-1185
Anyone know the actual dimensions so I can find maybe a modern alternative?
You may want to try this: http://www.ebay.com/itm/Leaf-Spring-...-/302045446302
Three years ago, when I ordered them from NAPA, one of the numbers was obsolete, but the counter guy was able to find a substitute.
Darned if I can find those numbers anywhere in my notes
But, I see that BJ's has both bushings for the front springs
http://www.bjsoffroad.com/M715-M725-...ng_p_1675.html
My truck wandered all over the road so I bought a pair of front springs from AB Linn years ago. New springs, new bushings all at the same time. And, I think they were less than $100 including shipping. I only wish I had ordered rear springs as well. One of the six grease fittings will not accept grease. I guess a little "hot wrench" action may encourage it
Yeah, been there with the rear spring posts. Like was said use a drill bit by hand and try to get all the old nasty hard grease out. A little bit of heat from a torch might help to get the little plug of grease out of the hole in the post that lets the grease go from the inner passage to the spring bushing. A little right angle pick might help too if can find where the hole in the post is.
