Doing some shopping for my brake system and discovered I needed a master cylinder boot. Could not seem to find one or a cross but mine had the part number on it. Found it by dropping the "C" off the part number. Wagner F-10901.
Sent the fuel pump to Then and now for a rebuild, was going to do it myself but after reading some of the threads thought it best to send it in. I am glad I did, the insides were pretty crusty, I can also see they welded a bushing in the pump arm which was quite loose, a very nice rebuild.
When restoring my WWII jeep there were a lot of these split rivets to install so I made a tool that installed them so when installed had the factory look. I used a cheap vice grip for the crimpers, cut an old thread die and shaped it for the crimp die and a flat plate for the backer. The tool came in handy again for the M715 windshield brackets.
Nice work with the split rivets and the installation tool.
When you have a welder, you can build pretty muck what ever you need.
1969 M725 ambulance
Do any of the trucks have a spare set of dash data tags and plate? I just picked up a '67 M715 project and the dash plate/tags are missing.
Mark
Yes I have 2 sets extra, one 725 and one 715.
Thanks- Id be interested in the one for the M715. I know the DOD and s/n would be wrong but at least I would have the rest of the tags and the plate that mounts them.
