Results 1 to 8 of 8
Thread: tire size ?
    Dec 2008
    ST LOUIS,MO
    Default tire size ?
    I would like to see some trucks with a spring over with two leaves taken out of the front to see what i want to go with? Maybe some pics of a 37,38,39.5 tire. thanks.
    Here is a springover with 39.5's with 2 springs out front and rear...both trucks were built by the same guy...different front tires but both the same 39.5 size on the sidewall:
    Note those are 15 inch rims over stock drums as well...something that seems like it wouldnt work but does.
    Looks like the those fit only because the backspacing is so short that the rims don't actually fit over the drums.
    Hey Brute do you know how wide those tires are and what the back spacing is.
    68 M-715 460 Ford
    I do not know the backspacing...
    The tires are either 13.5 r 15.5 wide...I think the tan trucks are narrower and the green trucks are wider.
    Jun 2017
    Louisville, Kentucky
    Where does he get the rims?
    One guy made both sets of those himself.
  1. Largest tire size on stock rim?
    By res0wc18 in forum Stock Tech
    Last Post: July 10th, 2009, 11:14 PM
  2. Tire Size Question
    Last Post: December 20th, 2008, 06:49 PM
  3. Tire flap size
    Last Post: November 25th, 2008, 12:18 PM
  4. Stock Rims and Tire size for M715
    By ochartman in forum Modified Tech
    Last Post: November 18th, 2008, 03:15 PM
