Results 1 to 10 of 19
Thread: Lets try this picture thing again
    Washington State
    Default Lets try this picture thing again
    Shot with E900 at 2007-08-07
    Almost finished with the rear, need to install tailgate chains and covers.
    I built protective steel light buckets for my led truck lights. Thanks Dan for helping out with the final mounting.
    My cab and bed mounts are homemade from 3/4 " inch barn stall matting. My truck has a 3/4" body lift added in for a little extra room. This stuff is harder than rubber, softer than poly and cuts and drills pretty easy. Now on to gas tank mounting. Slow but sure.
    Looking good! I like those blackout gaurds.
    68 M-715
    67 M-725
    VERY nice work!
    Waaaa, that's real nice. Good job!
    Springdale, Arkansas
    Now I'm jealous! Your stuff looks way better than mine, especially the paint.
    New Jersey by Philadelphia
    Your tailgate is arrow straight...did you do any bodywork to it or was it just super nice to begin with??
    Washington State
    Thanks, that Gillespie is a dream to shoot. Get your prep. work and primer nice and smooth and shoot a couple coats, it lays out perty.
    Washington State
    I bought the straightest tailgate I could find. The rib behind the left reflector was badly damaged, caved in. I cut the whole thing out and dollied it flat and re welded it back in. Also the two center hinges were badly bent. The one on the left I was able to straighten. The one on the right I had to completely remove and straighten then reweld back on. There is hardly any body putty, just a couple small areas to fill in slight imperfections. I also stripped it down to bare metal before priming and painting. The very bottom of the tailgate was pretty bent up too. I spent lots of time dollying that piece straight as well.
    Mar 2004
    northern Arizona
    looks really sharp!
    67 M725 67 M715 68 M715
    Geeze, thats a lot of work done to that tailgate. Have to say, the tailgate looks so straight. I coulda swore that was factory original, but I couldn't be because it doesn't have "the dent".
    Looking better with each picture. Hey, where did you get that spare tire cable winch?
    68 M-715
    67 M-725
  1. Saxon - lets see those 20's
    Last Post: February 3rd, 2009, 11:06 AM
  2. What the heck is this thing?
    Last Post: May 16th, 2008, 10:29 AM
  3. Saying Good-bye is a hard thing to do...
    By kwai in forum Open Discussion
    Last Post: May 9th, 2008, 12:04 PM
  4. I think I did a stupid thing
    By adk4x4 in forum Stock Tech
    Last Post: July 12th, 2007, 08:57 AM
