Old January 16th, 2018, 10:22 AM
67M715's Avatar
67M715 67M715 is offline
Private 1st Class
67M715 is a Soldier
Default Gear Swap Questions --- any interest in 4.10 or others?
We've (BJ's Off-Road) have been offering a 4.56 gear conversion kit for the M715 for a few years now.
Dana/Spicer has discontinued the Dana 70 4.56 offset gears and we are totally out.
We talked to a shop that can modify the carrier bearings so we can use regular Dana 70 gear sets in the M715 offset rear end.
Is there any interest in this? It would make all numerically higher gear sets 4.10, 4.27, 4.56, 4.88, etc available to swap in the M715 rigs.
Let me know if there is any interest and we will pull the trigger on the cost of getting these bearings tooled up for and modified.
Thanks!
1967 M715 w/ 454 and TH400
Old January 16th, 2018, 04:28 PM
Scassidy's Avatar
Scassidy Scassidy is offline
Basic Trainee
Scassidy is a Soldier
Aw man! If I would’ve known this a month sooner I wouldn’t have started converting mine to a 14 bolt, lol
Old January 16th, 2018, 04:35 PM
Jonnie's Avatar
Jonnie Jonnie is offline
Jonnie is a Soldier
I was interested in your original kit, this would be similar with more options?
Jonnie
Old January 16th, 2018, 06:02 PM
Uncle Vin Uncle Vin is offline
Uncle Vin is a Soldier
Yes. It would make the truck more road friendly. Please make them.
Old January 16th, 2018, 06:16 PM
78FordF150 78FordF150 is offline
Basic Trainee
78FordF150 is a Soldier
If the only modifications needed is to the bearings I would think it would be a no-brainer.
Sent from my SM-G930P using Tapatalk
  #6
Old January 17th, 2018, 05:43 AM
lelant's Avatar
lelant lelant is offline
Basic Trainee
lelant is a Soldier
Yes, interested!!
  #7
Old January 17th, 2018, 05:58 AM
Nailhead Nailhead is online now
Corporal
Nailhead is a Soldier
I would be interested in 4.88's: they worked great in my Hercules M37, and would like to that option with the 715.
  #8
Old January 17th, 2018, 10:40 AM
67M715's Avatar
Private 1st Class
67M715 is a Soldier
Quote:
Yes, this would be similar with more gear options.
We have told our shop to go ahead and develop this, it should be available sometime in the next couple months.
  #9
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Modifying the bearings to move the carrier over? Trying to picture that... but I'm not a real mechanic, just pretend to be one while trying to fix stuff that breaks.
Would that involve using a narrower bearing on the starboard side?
I've wondered if using a spacer behind a newer ring gear to make up for the offset would work. But more axle work is a few years down the road so haven't wondered about it too much. and figured if it was that simple someone would have done it or made a kit by now.
Mr. Boyer put a spacer behind a ring gear on his truck but I think it was while installing a limited slip on the front...
  #10
Old January 17th, 2018, 10:56 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Quote:
Okay. Did some quick googlin... looks like I had it backwards in my head..
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
